I sprayed both the Sound Control (SC) and Ceramic Insulation (CI) on the inside of my firewall and foot panels. On my floor pan I am spraying the SC and CI on both the top and bottom. I have not sprayed the CI on the top of the floor pan yet but will probably this weekend. I can that say tapping on the floor pan before and then after there is a big difference on the sound of the sheet metal. Just from the way it feels and sounds I think there will be a big difference.
Tim
I suggest you rough up with 40 grit any place you are applying Lizardskin. It will hold it better. Great stuff and paintable as well. I use it on the entire interior of the body as well as the AL panels.
Thanks all for input
I have done firewall and several other parts with the Lizard skin (Heat and sound). Very impressed with product, seems like sound barrier will work good and I would expect heat barrier will alsolizard skin spray 2.JPG work.
Lizard Skin should only be applied to inside surface, per instruction on label as it is not road grim resent and well soften if cleaned with solvents.
