How are most of you attaching the fiberglass trans tunnel to the chassis? I assume you want to be able to remove this if the need arises, so are you using screws and rivnuts and if so are you installing them in the fiberglass and then placing screws in from the bottom or just putting the rivnuts into the top surfaces of the chassis tubing?
