1965 FFR Challenge Cobra Roadster Street Legal CA Title
Built in 2008, Ford 5.0 HO V8, 5 Speed T5 Transmission, 3-Link 8.8 Rear Axle, Coilover shocks and Disc Brakes all around, clean CA Title in Hand
$25k Firm
Engine
Configuration 8 cylinder iron block
Stock Mustang 87-93
Displacement 302 CID
Compression ratio 9:1
Induction Multi-Port fuel injection
Max Horsepower 225 hp. (stock)
Max Torque 305 ft.lb.
Max Engine Speed 6250 rpm
Drivetrain
Transmission Borg Warner T5 5 Speed
Rear Differential Gear 2:73 : 1
Clutch Stock Mustang 10.5"
Bell-housing Lakewood Scattershield
Suspension
Front Suspension Independent un-equal length
Upper and lower a-arms
Rear Suspension Solid live axle, 3link
Shocks-Springs 4 corner aluminum coil-over
w/ ride height adjustment
Steering Power rack and pinion
Brakes 11" front discs and 10.5" rear disc brakes
Wheels 17" x 9", 5-spoke wheels
Dimensions and Weights
Minimum Weight 2450 lbs. (incl. Driver)
Weight Distribution 46/54% (front/rear)
Wheelbase 90 in.
Overall Length 13'6"
Track (front/rear) 56.0/58.5 in.
Overall Height 46.5 in.
Overall Width 72 in.
Ground Clearance 4.0 in.
Construction
Layout Front engine RWD
Frame Tubular space frame
Roll Cage 6-point cage, integral to frame
Sub-structure Aluminum chassis panel, bonded and riveted to frame.
Body Hand-laid vinylester resin composite shell with 3/16" laminate.
