8
Things that make this build different from the others:
1. This car is built from a forester donor rather than a wrx donor.
2. We are attempting to use a 32bit SAVCS forester wiring harness and ECU.
3. The transmission and TCU will be from a BAJA along with the sport shifter with "tap up tap down" shifting. We will also be attempting to use the JDM paddle shifters behind the forester steering wheel.
4. We will be attempting to retain power brakes, but keep them from being overly sensitive, by using a JDM Miata brake booster.
5. We will be attempting to retain the ABS from the forester.
I will backtrack and update this post as the build progresses.
this is the good forester (my daily)
this is the donor forester (my beater) I dont have many good photos of it, but heres a drone photo from our last get together (it's the silver one in the woods)
