Results 1 to 40 of 404
Thread: iWire Turn Key 818 Harness for R and S Models
Threaded View
    iWire's Avatar
    Lake Forest, CA
    Check out our interactive customer map!
    ECU Plates are finally in. Comes standard with V4 harnesses. iWire V1-3 customers can purchase them for $65 plus shipping, non iWire harness customers for $100 plus shipping.
    V4 manual completed and up for anyone to check out how simple the install is.
    Non Drive by Wire Engine Install Manual
    We're now shipping V4.0 harnesses that have been updated for a better fit, upgraded materials, and an ECU box to protect for the elements. In addition we're now a Cobb Tuning authorized dealer so make sure to grab an Accessport with your build!
    For those who are looking at having us build you a harness, the sooner you get a hold of us the better we can fit into your project timeline. We have streamlined our process while still giving you the ability to customize to suit your needs and with that you can now expect approximately 4-6 week wait. If you need a specific time frame please let us know.
    The goal of the kit was to build a high end race spec harness that is completely plug and play, built from scratch using bits from your Subaru harness, and customized to individual specifications. The end result is a turn key harness that can be for any type of build from the simple to the complex. Our main focus was to turn a wiring process into a mechanical one. All you need to do is to run the harness, sand a couple spots for grounds, bolt it down, and hook up the battery. Assuming the mechanical is ready to go, it should only be a couple hours of work before you'll be able to rip the car down the street.
    Includes:
    • All Kits come with 3 fuse boxes with accessory, key on, and constant power and all basic equipment from engine to headlights, taillights, cluster, turn signals, etc.
    • ECU box for mounting and protection from heat/moisture
    [*]$65 Mounting hardware
    • Adhesive or screw in tab with heavy duty zip tie
    • Self-fusing rubber tape to eliminate any vibration between the harness and clamps
    [/LIST]
    Options Include:
    • Cruise Control
    • ABS
    • Daytime Running Lights
    • Power Mirrors
    • Many more, just ask!
    Pictures of completed R and S harnesses can be found here -
    126 Justin S. 2.0 WRX Powered 818 #1181
    125 Ian P. JDM V7 Powered 818 #1178
    124 Terry B. 2.0 WRX Powered 818 #1177
    123 Johannes E. 06 WRX Powered 818
    122 Lawson S. 2.0 WRX Powered 818
    121 Christopher E. 06/07 WRX Powered 818
    120 Bill S. 06/07 WRX Powered 818
    119 Devin P. 2005 STi Powered 818
    118 Mike B. 2005 WRX Powered
    117 Kent S. 2.0 WRX Powered 818
    116 AllPro Subaru 2.0 WRX Powered 818
    115 Erick C. 06/07 WRX Powered 818
    114 Jason F. 06 WRX Powered 818
    113 TJ K. 2.0 WRX Powered 818
    112 Kozmic Motorsports STi Powered 818 Race Harness
    111 Jay S. 06 WRX Powered 818
    110 Ben B. 06 WRX Powered 818
    109 Joel B. 2.0 WRX Powered 818
    108 Barry R. 2.0 WRX Powered 818
    107 Wendell H. 06/07 WRX Powered 818
    106 Keith C. 06/07 WRX Powered 818
    105 BC H. BC H. 2.0 WRX Powered 818
    104 Glenn R. 2.0 WRX Powered 818
    103 Jeff B. JDM GD STi Powered 818
    102 Craig R 2.0 WRX Powered 818
    101 Tommy T. 06 NA powered 818
    V4.0 Harness Pictures
    Where you see empty looped wire, keep in mind they are extras added in by customer request for auxiliary power, ground, and signal wires to run fans/gauges/lights/etc.
    Combined Full Harness
    ECU to Engine Section
    Front Harness Section
    Rear Harness Section
    Alternator - Battery - Circuit Breaker - Ground Strap
    ABS Sub Harness
    Detail Shot with Adhesive Lined Shrink Tube to seal, add strain relief, and clamp the split sleeve
