Thanks Thanks:  2
Likes Likes:  26
Page 1 of 3 123 LastLast
Results 1 to 40 of 93
Thread: DamnYankee Build Thread
    Senior Member DamnYankee's Avatar
    Port St Lucie, FL
    My truck kit was delivered today. Will be open wheeled. I have the crate LS3 6.2 with a T-56 manual. Moser rear. Wilwood brakes.
    Haven't decided on wheels yet, but soon I hope.
    Inventory tomorrow :-)
    Ron
    20190210_172756 (Small).jpg20190210_203244 (Small).jpg20190210_172556 (Small).jpg20190210_172731 (Small).jpg20190123_151947 (Small).jpg20190114_161029 (Small).jpg
  2. Likes Straversi, nthompson, Houdini liked this post
    herb fraser's Avatar
    Looking Good !
    Congrats! Looks like Christmas in Feb. LOL.
    Port St Lucie, FL
    Finally making some progress on my build. Either I was out of town, or I had company.
    Brakes plumbed, suspension and steering installed.
    I had firewall hydro-dipped with a carbon fiber pattern. Hard to see in pics, but it does look cool.
    Painted the engine and now installed with transmission. Using LS376/480 with a T-56 Super Magnum.
    When I installed the electric power steering motor it was hitting the LS oil pan, so it needed to be clocked down to clear the pan, but this made it the lowest thing hanging under the chassis, which I didn't like. So I ordered 2 oil pans from Summit to see which would work. The first one I opened was the GM 12628771, and this fit the power steering motor perfectly. The motor is 3/4 inch below the pan, but still 3/4 inch above the chassis. I also had to use oil pickup 12558251, and windage tray 12558253. The original dipstick worked fine. The other pan was Holley 302-3, and I never opened the box, just returned it to Summit.
    Took me a while to find wheels that I liked, and fit. I liked the looks of these Milanni Kapri, but they were discontinued. The 20s were still available, but not the 18s. I saw a set of used 18s on eBay but seller wouldn't sell me only 2. So in late March I was in Los Angeles visiting my son and discovered that the wheel distributor with the used set was in East LA. So I drove over there and measured the back of the wheel to be sure my Wilwood calipers would clear, and they did. They still wouldn't sell me 2, so I bought all 4. Then 2 days later they sent me an email saying 2 of the wheels got damaged in the warehouse preparing for shipment, so they refunded half my money and I got the 2 that I wanted to begin with. And was able to get the 20s on clearance somewhere else. Winning !
    Next on to fuel system.
  6. Likes Straversi liked this post
  7. #5
    Looking good!
  8. #6
    Nov 2018
    Scurry Texas
    What size tires did you go with. Look good
  9. #7
    Port St Lucie, FL
    Rears are 315/35-20.
    Fronts are 255/35-18.
  10. #8
    Port St Lucie, FL
    Fuel system completed. I prefer to use aluminum hard fuel line because its much easier to bend and route. Used braided PTFE for all the connections.
    20190419_101735 (Small).jpg20190430_113805 (Small).jpg20190430_140605 (Small).jpg20190430_140614 (Small).jpg20190430_140618 (Small).jpg20190430_142401 (Small).jpg
    Completed the floor with the foam cores. A little messy but worked out well.
    20190426_152053 (Small).jpg20190426_154052 (Small).jpg20190426_160927 (Small).jpg20190426_164842 (Small).jpg
  11. Likes Houdini liked this post
  12. #9
    Nov 2018
    Scurry Texas
    That looks like a great idea on the floor pan. Can you explain a little on what you did there?
  13. #10
    Port St Lucie, FL
    The foam sandwich floor is part of the kit now. Has a bottom piece of aluminum underneath, then the rigid foam, then top piece of aluminum. Acts as a heat barrier and sound deadener.
  14. #11
    Nov 2018
    Scurry Texas
    Good to hear. I have a completion date of the 18th so should be included. Thanks!
  15. #12
    Port St Lucie, FL
    Mounted my LS fly-by-wire gas pedal. I cut up the bracket which came with the pedal, then welded it to the side of the pedal box. Because of this I'll have to move the fuse box mount about 2 inches to the right.
    20190507_115215 (Small).jpg 20190507_144255 (Small).jpg 20190507_145804 (Small).jpg
    Got my tunnel fitted. Plenty of footbox room around the pedals.
    Not sure why the 2 thumbnails are here.
  16. #13
    Port St Lucie, FL
    Making progress:
    Used LS Serpentine System from EddieMotorsports. Worked out real well.
    Mounted radiator and AC condenser. Used 33 Hot Rod fan shroud from Mike Everson, did a little trimming to make it fit.
    Miles of wiring between the FFR wiring and the LS wiring. Used Dakota Digital dash which eliminated a good bit of wiring.
    20190513_164134.jpg 20190513_171639.jpg 20190520_151709.jpg 20190606_112331.jpg 20190607_143521.jpg 20190606_111542.jpg 20190608_192616.jpg
  17. #14
    Port St Lucie, FL
    Port St Lucie, FL
    First start was tonight 6/15/19.
    First time I've had an LS, love it. No timing to set, no carb to set. Just add fuel and crank, and it idles!!
    Actual first start:
    https://youtu.be/CTpB2j8u24w
    Second start:
    https://youtu.be/h_NQPBSGb9M
    Third start:
    https://youtu.be/r036Fw_EbHQ
  19. #16
    Congrats!
  20. Likes 35 Ford Hoonatruck, Bakers35 liked this post
  21. #17
    Port St Lucie, FL
    Wipers installed -
    I know many people decided not to install wipers, but my plan for the truck was to make it an all-weather vehicle. I installed wipers in my Cobra when I built it. So I wanted wipers from the truck one way or another.
    I looked at a few different styles including the simple motor units like Speedway sells or Mighty Wiper. But the motors were too big to not interfere with the dashboard.
    I ended up with the Universal Wiper Kit WWK-2 from Specialty Power Windows which arrived today via UPS and I installed it in about half a day or so. It uses the tube and cable system same as the Cobra uses. The transmissions are small and fit where I wanted.
    So for those interested I'll outline what I did below. Total cost with arms and blades was $368.
    First step is to determine where to drill the holes for transmission shafts and how to space them. I kinda copied the way they were spaced on my Cobra.
    Driver's side shaft is 9 3/4" from edge of windshield. Passenger side shaft is 15" past the driver's side shaft.
    Drilled 3/8" holes located 1/2" above the cowl. I wanted the transmissions to be as low as possible to not interfere with dashboard.
    Did not use any bezels, not needed
    I ran the jam nut on the shaft down tight against the transmission body, put a 3/8"flat washed on, and slid into the hole from the inside. Cable channel is on the bottom. Top of the transmission will be at the bottom of the fiberglass lip for the windshield.
    From there follow the instructions to shorten the shafts.
    I mounted the motor where the passenger side kick panel would be. I made 2 brackets to bolt it in.
    Then cut and flared the tubing and installed the cable.
    Whole project went better than I expected.
    And with the truck's removable dash I don't see any reason why this couldn't be retrofitted to a completed build.
    Disclaimer: My windshield is not yet installed so I couldn't test the sweep. But I'm pretty confident it will be functional.
  22. Thanks Straversi thanked for this post
  23. #18
    Nov 2018
    Scurry Texas
    Thanks so much for sharing this! Ive been digging and digging trying to figure out a way to go. please post an evaluation after glass install.
  24. #19
    Aug 2018
    Hampshire, IL
    Thanks for the post. I’ve been comptinplating on weather or not to go with wipers but I might have to here in Illinois to get through inspection. I’m at the crossroads right now with body work and removing the cab for paint so now would be the time to do it . However I’m at somewhat of a standstill due to too much work and going up to Canada fishing so my build is on hold for a month and a half or so. Thanks. Rob
  25. #20
    Apr 2018
    Colorado Springs
    Thanks for sharing.
    Less thinking I have to do now!
  26. #21
    Feb 2019
    Big Island Hawaii
    Thank you for this post!!! my DMV requires wipers and I have been waiting for someone to figure this out.....I already ordered this setup. Which wiper arms did you order?
  27. #22
    Port St Lucie, FL
    Got their straight stainless arms and flat blades.
  28. #23
    Senior Member FLFrank35's Avatar
    May 2019
    Viera, FL
    Thanks for posting this!! I live in FL too and would like to install wipers since it's easy to get caught in the rain.
  29. #24
    Jan 2019
    I was wondering what Rear End Gear Ratio you used for your build and what your first and final gear ratios in your tranny were? The T-56 seems to come in may different sizes.
  30. #25
    Super job on the wipers!
  31. #26
    Port St Lucie, FL
    Quote Originally Posted by CoreyGp View Post
    Rear is 3.55
    Trans gears are:
    2.66
    1.76
    1.30
    1.0
    .80
    .63
  32. #27
    Port St Lucie, FL
    Mechanical and electrical done.
    In full bodywork mode now. I can build or fix anything, but I am not a body guy. However I am doing this myself with tips from the forums and coaching from my buddy who is a 30+ year body/paint man.
    Doors are fitted, hood and radiator cowl fitted. Bed is drilled for mounting. Currently doing the cab seams. This is worse than sanding drywall spackle, which I also hate !
    20190712_185605.jpg 20190716_191721.jpg 20190729_162533.jpg 20190806_130241.jpg 20190807_114950.jpg 20190808_160208.jpg 20190819_112915.jpg 20190820_160357.jpg 20190821_143801.jpg
  33. #28
    Nov 2018
    Scurry Texas
    Quote Originally Posted by DamnYankee View Post
    Looks great. What are you going to do with your grill? I cant make up my mind
  34. #29
    Port St Lucie, FL
    Quote Originally Posted by bnelson View Post
    Either black it out, or body color which will be dark gray or silver.
  35. #30
    Jun 2019
    Whitehouse TX
    Look great. Wish I was that far along.
  36. #31
    Gatineau, Quebec, canada
    The key is to not cheap out on the body filler, use premium quality products like Evercoat Rage, Rage Ultra or Rage Gold, they sand MUCH better and self seal as well. It will save you time and money in the long run. As well make sure you borrow your buddies long sanding board to get that flat smooth surface. Once you get the bodywork out of the way the rest is a breeze!!
    Good Luck!!
    Andreas
  37. #32
    Now you see why I do not sand or paint my builds. I farm that out. Not my idea of fun either Ron.
  38. #33
    Jun 2019
    Whitehouse TX
    How did you get the side engine covers in place? There has to be a secret!
  39. #34
    Port St Lucie, FL
    Quote Originally Posted by sperger72 View Post
    I cut the side covers:
  40. #35
    Jun 2019
    Whitehouse TX
    Thanks. Just glassed the metal strips in place?
  41. #36
    Port St Lucie, FL
    yes with DuraGlass
  42. #37
    Jun 2019
    Whitehouse TX
    Port St Lucie, FL
    Started primer this week.
  44. #39
    Looking Good!
  45. #40
    Port St Lucie, FL
    I finished the bodywork and primer. Going for final paint in 2 weeks.
  46. Likes Straversi liked this post
