Originally Posted by
Plimpton
I see you mounted the front upper control arms to the lower holes on the frame tabs. I assume you will do the lowers the same way. I think the two hole tab is new for Gen 2. I can’t find where (or if) the manual addresses which hole should be used and why. How did you decide to use the lowers?
‘The suspension has two sets of holes. The top set is for the Hot Rod while the bottom set is for the Truck.’
33 Hot Rod #1133. LS/TKO600
Titled 2-28-20
MkI.IV 2643k
Consummate Learner
sethmark
I question that because the truck uses a different chassis...
TxMike64
Its right out of the April revision build manual. I have to assume they’re building one bracket set to use on either Frame.
Titled 2-28-20
MkI.IV 2643k
I had to use the upper holes for the lower control arm to get the arm to be able to droop - no choice. I used the Upper holes for the Upper control arm to have the Radiator mount OK. I did use the lower hole on the upper shock mount which will raise the ride height a little bit.
Back to using the lower hole with some rubber between the bolt head and the frame. Will continue to try and figure out the best settings.
- Peterh226 #1134
