CONGRATS!!! Other than good luck the first piece of advice I can give you is to get the body, doors, trunk, hood all fit up and aligned with each other (you will need to fit up the rad with the front grill as well) first before you get into all the other fun stuff!! This will not only test your patience but it will get you way ahead when it comes to the rest as that portion can go very quickly and the least amount of dust on it the better. This is a lesson I learned the hard way and now understand this is the way the other "full time builders" do it as well as at FFR. Doing body and fitment early on also lets you ensure good alignment for the rest of the components afterwards.
Oh and most of all HAVE FUN!!!
