0
0
Originally Posted by
Bob-STL
Bill, The tow guys attached the cable to the open hole at the front of each 4 inch frame tube (Gen 2). In addition, we used two 2x12x36 boards under each front tire to raise the nose high enough to clear the tilted bed.
Wow that was lucky the cable actually cleared the Coupe's lower body OK at that angle.
I am forever haunted, having seen the lower under-grille panel of a friends aluminum bodied AC Bristol, bent upward and outward by the cable. It made quite a mess.
