Here's a pic of the "plate" I'm talking about. The two circled slots seem to be appropriate for bolts to hold the door shell onto the door frame assembly at the hinge end.
here is the only thing I can find in the manual - seems to want me to drill 2 holes in the plate and put aluminum screws in. Other than scribing the lower slot on the rear plate into the door, there is no further reference...
So the question is, what did you guys do to attach this plate to the door skin? I'm inclined to scribe both slots into the door skin, drill through the center of the slot (leaving adjustment in both directions) and use a flange head bolt from the outside with a locknut on the inside. If that's what you did, did you use bolts from the kit (which package) or did you buy extra?
Thanks for the help
