Likes Likes:  2
Results 1 to 15 of 15
Thread: Trunk hinges
    Trunk hinges
    Stock trunk hinges keep breaking.
    I've had this car for 10 years, no problem, wife lifts trunk to get groceries, one hinge breaks. (three weeks ago)
    I replace both. Mechanic lifts trunk, one hinge breaks (two weeks later).
    I use one good hinge from each of the two sets, go for ride, both hinges break! Almost lost trunk!
    Are there after market hinges available, I'll go looking, or I'm going to have some made, not going to use stock hinges again, that's 4 breaks in 3 weeks!
    FYI if you are not aware; they are right and left specific. If you mix them up they are prone to breaking.
    What Jeff said. Look at the profile of the hinge. You will see one side is taller than the other. The tall side goes to the outside of the car. Also I believe they are labelled "L" and "R" on the underside.
    The visible end of the hinge pin faces inboard. Those hinges, at best, open the trunk to a 50* angle before they start to roll and twist towards each other. It's a geometry thing...da bat
    The first one to break has been on the car for over the ten years I've owned it, no telling how long before that...
    I did not know there was left/right, my error, went to manual, yup, you guys are correct, so now to order new set, or rummage through my shop to see if I have another set laying around
    Thanks for the information!! Always helpful here!
  6. Likes Aircontroller liked this post
    I know for a fact that I have one in my shop. I will let you know what side. You can have it for shipping. sure someone else will have some as well.
  8. Likes Aircontroller liked this post
  9. #7
    Thanks Michael I'll PM you my info.
    I'm headed over to post in wanted area.
  10. #8
    I will send one out today. Pretty sure its a left.
    mike
  11. #9
    Thanks, Michael. I will check out the one of four I have that is not broken, to see if it's left or right, thanks, we may have a pair, bit early out here in California, and cold to go out to shop, need another cup of coffee.
  12. #10
    Michael, I have a good left one!
  13. #11
    I have a bucket of parts and pieces if you need any more...da bat
  14. #12
    j.miller, helpful, as always, I'll be calling you, thanks.
  15. #13
    ok I will not send
  16. #14
    Thanks Mike, maybe someone else can use it.
  17. #15
    Da bat, I got the hinges, thanks
    BTW, guys, Miller sent me hinges for free, wouldn't even let me pay shipping! Class act!
    J. Miller, you are one of the good guys, that make this club great!
