Not a waxer
As for the tire rub you have at least two, likely three things working against you.
Wolffbone
...275x60x15bf goodrich radial ta tires...
1. Rear tires that are too tall
Wolffbone
...the rear end came from 1995 mustang...
2. A rear axle that is too wide
Wolffbone
..the wheels are american racing 5 spoke....
3. It's very likely that these wheels have the wrong offset and backspace, especially given the fact that they had to use a pretty significant spacer in the front.
As for the poor braking my bet is that when the booster was eliminated the builder failed to do the pedal modification to change it to the proper leverage.
Good luck,
Jeff I will do more homework Monday getting a feel for what's going on not a lemon just not as finished as I thought
Also not sure how to ask questions on forums
Figured out how to post new thread finally
