Tremec t56 vs. TKO 600
I've ordered a Type 65 kit and am going through engine and tranny options in advance of the kit arriving. My kit order is for a TKO but now am hearing that it doesn't shift very well and has a low RPM ceiling. I'm planning on finding a Gen 2 Coyote F150 engine for a donor and then modifying it a little (might rev north of 7,000).
Could you offer some guidance regarding staying with the TKO or switching to a t56?
Thanks.
Though the TKO is a solid transmission, the T56 is far superior in the shifting department, plus you get that extra gear.
In addition, since the Type-65 has a 95" wheelbase compared to the MK-4's shorter 90", the T56 is a more viable option in that chassis.
From my perspective, if you have owned a car with a 6-Speed you'll never want to own a car with a transmission with fewer gears.
Add in the T56 hydraulic clutch and it sort of seals the deal.
Good Luck & Hope This Helps!
Seasoned Citizen
The TKO-600 does not like to shift quickly at higher RPM in it's stock form. However, Liberty Gear can modify that and you can actually purchase a TKO trans directly from Liberty already modified (or send yours to them). http://libertysgears.com/our-products/tremec/
Do you're homework -- the TKO is a good trans but for higher RPM use does need some basic mods to improve shifting. Just depends on how you intend to use your car.
33 Hot Rod Super Pro Drag Racer Build:
33 HR NHRA Cert Roll Cage Build
32J liked this post
