Originally Posted by
narly1
I'm planning on setting up the layers as follows:
passenger compartment
interior carpet
sound damping matting
inner aluminum panel
homebrew lizard skin made from a mixture of glass microballoons & self etching aluminum primer
FFR insulation
"outside" aluminum panels
Rhino bed liner
road surface
From your experience it sounds like I should be adding 1 or more layers of the DEI BOOM mat (or similar) as well. The question is where? I haven't checked yet, is there enough room between the lower and upper aluminum panels for the BOOM mat to fit in as well as the FFR provided insulation? And/or a 2nd layer between the inner panel top side & the sound matting?
Earl
The insulation panel's FFR supplies fills up that cavity to the top, so unfortunately there is no room to add a layer of boom mat under the aluminum sheet. It sounds like from above you should be fine. with everything you're doing. My only point is the sheet aluminum-insulation-sheet aluminum alone is not a good plan.
Jim
Post Thanks / Like - 1 Thanks, 1 Likes
