Finished up plumbing the front brake lines last night......kept things low and tight in the pedal box area and stuck close to the frame where-ever possible. Working in the front shock area was fun but it turned out okay so I'm happy.
Still waiting on my 90 degree 3 AN male to 1/8 NPT 90 degree fitting for the hydraulic clutch M/C
Also brought home the engine/tranny so I can swap out the valve covers & air cleaner with the ones I bought (went with black with red lettering Ford Racing covers, air cleaner & breather). Also need to remove the mechanical fuel pump and get the block off plate installed since I installed an electrical fuel pump.
The rear brake line is ran to about mid chassis, I'll finish that up one of these nights.
Will start on the electrical next.
Post Thanks / Like - 0 Thanks, 4 Likes
