All,
I've been reading through the threads for this topic and want to tackle how to wire these correctly.
Examples:
https://thefactoryfiveforum.com/show...-my-projectors
https://thefactoryfiveforum.com/show...h-Auto-AC-HVAC
I bought some 2- and 3-wire waterproof connectors to make the connections to the headlights, accent lights, and turn signals.
I have a 2006 WRX wagon donor - the wiring guide in the attached pictures show the wiring diagrams for the high/low beam wiring along with my notes. Here's some of the items confusing me:
1) I have nothing that shows what pin #6 is, but the wire looks the same as pin 5. I drew what my guess is, but it doesn't make sense because the LH headlight pin 5 will also activate the blue high-beam indicator light on the gauge cluster. Any ideas?
2) because of item 1, does anyone know if the low beams will shut power if highs activate? I've seen the notes about the shutters and such with the new lights. I'll probably do the pin voltage check that Mechie3 posted to do, but I can't do that right away because I have some more grounding to do first.
3) Is there a way to include the accent lights in the headlights for DRL, but at full brightness? They're already pretty dark and half-voltage may not show anything. Alternatively, how do others have them wired?
Thanks everyone, this community is the best.
