I used 40 mil thick vinyl from home depot - the kind normally used as a moisture barrier. It's cheap and worked well.
I've also got the hydramat but the older Boyd tank and have never experienced a fuel starvation issue. As I understand, as long as any part of the hydramat is touching fuel, it will work as intended. If the edges are sticking up, that shouldn't be an issue.
