2014 818S For Sale
I started this Build in late 2014 so it's been a long journey. Mostly by myself, but had help from friends when I needed 4 or 6 hands. I didn't do any of the engine or trans rebuilds. The car is built from a 2002 Surbaru WRX 2.0 turbo. The car runs good and is nearly complete but Life changes and I need to simplify. I'll list what i've done and modified. And what it needs.
License and Registration: The car is fully Registered with California plates and insured
Frame: Powder coated from Factory5
Motor: I had it rebuilt in March of 2015 by Ubersport Performance in Orange Ca.
They tore down the motor, machine bore and honed the block and heads. Align Bore, Deck heads and block.
Engine was Blueprinted and re-assembled with Manley forged pistons, King Bearings, ARP head studs, Gates timing and water kit.
Subaru oil pump. Exedy stock clutch, and refinished flywheel. TGV deleted.
Turbo: The Air/Air Intercooler is replaced with a Water/Air Intercooler. (Reliability is better than speed!)
Transmission: It was rebuilt at the same by Stu's AE Transmission in Long Beach.
New Gasket and Seal kit, Synchro sets, Ball Bearings, Oil seal and Retain rings.
Wiring: I used the original loom and labled it but Ubersport installed it. (Very confusing)
Brakes: I used stock WRX brakes. I rebuilt the calipers, replaced the rotors and pads and added a brake booster.
It stops very well!
Cooling: This was a big headache. I finally gave up and had welded stainless steel tubes and an aluminum
CXRacing radiator installed. New thermostat also.
Alignment: The car is set up for the street. I can provide specs if you're interested.
What is needed: ECU is not tuned. The motor does not have enough miles. Less than a few hundred miles.
Some body fitment. The front has been the most difficult. The bumper, fenders, and hood need to be aligned.
I have not installed the pin latches on the engine cover or the hood. Also needs paint.
The interior need finishing. Mostly carpet and a radio.
I am asking $13,500 obo. I have front and rear spoiler kits also. If you have other questions please ask.
