Results 1 to 3 of 3
Thread: Pre-Bent SS brake lines
    Breeze Auto discontinued their pre-bent stainless steel brake lines for the MKIV. The 289 lines should be the same. Does anyone know of a source for these? I am just awful at bending these lines.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    No idea if pre-bent lines are available, but what I will say is this... I was also really nervous about bending my own lines. It's really not that hard. Buy a roll or two of Nicopp to practice with. It's cheap and easy to work with. After you've screwed up 10-15 lines you'll get the hang of it and your lines will turn out great. To me, that's all part of the enjoyment of the build process - learning new skills. Also, buy a GOOD bender. The ones that are made to bend many different size lines are just an exercise in frustration IMO. I bought a dedicated 3/16" and 3/8" bender and they made life so much easier.
  3. Likes David Hodgkins liked this post
    Dublin, OH
    Take your time. Expect to waste a few pieces practicing. Use a large socket to create tight, symmetric loops for excess line. Don't forget to push the nut to the end before making a bend. I did most of my bends by hand and around a socket in my bench vise.
