Likes Likes:  2
Thread: Current Update
    Feb 2020
    Chicago
    Current Update
    Well, I haven't posted on the forums in a long time, due to using the FB threads, but here is a current update. Coyote Gen 3 is in. test ride is in the books. GPS has an issue with syncing correct time, and Speedhut is aware and assisting. In the process of mounting the seats w/o the body on using the Breeze seat mounts. (not sure a good idea). Just ordered the NRG quick release hub taking time on that. No leaks on the car (guess I got lucky). Need to order a tune from LUND.
  2. Likes GTBradley liked this post
    On a roll Al_C's Avatar
    Wheaton, IL
    Looking good! I have some photos from your engine installation that I will upload and post here, too.
    Feb 2020
    Chicago
    Thanks Al
    Lund tune requires extensive driving using various scenarios they will provide. Including wide open throttle (WOT) hits. No way I'd attempt that in the go-kart stage. Your engine is running. Go with that until you're done and legal. Then order up and complete the tune. No, not a good idea to mount the seats without the body. The fit is tight and you need the body there for reference. Unless you like do-overs. Congrats and getting to this stage.
  6. Likes FF33rod liked this post
  7. #5
    Feb 2020
    Chicago
    Thanks again Paul
  8. #6
    Senior Member 460.465USMC's Avatar
    Aug 2019
    Spokane, WA
    Congrats! Sounds great. I also ordered the Gen 3 Coyote. I look forward to getting to that stage someday.
    Coupe complete kit delivered: 4/22/24. Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
  9. #7
    Senior Member Nigel Allen's Avatar
    South Australia
    x2 on Paul's suggestion regarding delaying Lund tune. I have just been through that process with my completed roadster. One of the tests required 7,000rpm in highest gear possible. Even in 2nd gear I was at 135kph! So, I would not think it wise, or even really possible to pull this off sans body / windscreen. There would be so many ways for the constabulary that they just wouldnt be able to resist.
    Something to look forward to though; The Lund tune really got my motor running like it should. It now has more grunt than a pig sty.
    Nigel
    Gen1 Coyote / TKO600 / IRS
