Likes Likes:  2
Results 1 to 23 of 23
Thread: Door sill covers
    Sep 2019
    Door sill covers
    Hope everyone had a nice Thanksgiving. Am in the process of the final assembly of my hot rod. I noticed that I do not have any door sill aluminum covers. Are they supposed to be included in the kit or are they a option? Thanks Ray
    Placitas, NM
    They came with my Gen 1 kit. I can post a pic of what I was sent a little later today.
    Falmouth, MA
    I don't believe there are any true door sill covers. There are the pre-bent aluminum pieces that attach over part of the door sill and secure the top edge of the carpet but that's it. It would be nice if someone came up with a nice fabricated piece to wrap from the rear waterfall, across the door sill and up the rounded portion of the front door opening.
  4. Likes FF33rod liked this post
    Sep 2019
    Jim, thanks for your response. I thought there must be something that goes there as the sill paint would get damaged when you get in and out of the car, also it would cover the carpet seam. I was not able to find any reference of them in the manual. (not surprising) Ray
    Jun 2018
    North Vancouver, BC, Canada
    RR, there is that crude small piece that Jim referred to, it does hide the carpet edge and protect part of the door. However, as cob427sc said, it would be much nicer to have a properly finished longer pieces that looks professional. Innovative rodding does have a very nice door sill bit it is quite short and doesn't go all the way back to the waterfall etc.
    Gen 1 '33 Hot Rod #1104
    Placitas, NM
    It’s only an L shaped piece of aluminum. F33rod, do I have it on backwards?
    The piece on the running board shows the other side.
    Jun 2018
    Jim, I was thinking the other way around so it covers the carpet edge. I thought putting it on the way you show would likely interfere with the heads of the screws attaching the body at the door sill
  9. #8
    Placitas, NM
    I don’t have it fastened yet, just sitting there for the pic.
    I had it this way to cover up the screws. Think I’ll get more aluminum so I can make it a U to cover both sides.
  10. #9
    Thanks, I’d swear I didn’t have these or ever seen them before but this weekend I rearranged the garage and found these down behind my toolbox!! Interesting idea.. will cover up the body sill in case I need to space it as most seem to. But as Jim suggests I may make a better one.
  11. #10
    Sep 2019
    Thanks guys! After reading your responses I contacted Dave B. He informed me that I did not in fact receive them with my kit. He already sent a pair out. Jim what is that aluminum piece that is on the waterfall? Is there supposed to be another aluminum piece for the waterfall to body seam? Ray
  12. #11
    Placitas, NM
    Ray, that is the edge of the waterfall. I’ve painted it titanium silver.
  13. #12
    Sep 2019
    Jim, from what I can see it looks nice! Could you send me a better picture of your idea? Thanks Ray
  14. #13
    Placitas, NM
    Ray, a pic of the painted waterfall?
    I haven’t made the U shaped cover yet. Probably won’t get to that for a while, still doing body work, ugh.
  15. #14
    Sep 2019
    Jim no problem. I feel your pain about the body work! I think it took me 2 months before I was satisfied. I had so many pin holes in the fiberglass it drove me crazy. I used a lacquer based primer for the initial body work. I then sealed it and painted. Unfortunately I found a few pin holes that I missed. Luckily none on the body, hood or doors. If I ever do another one after I have finished all the body work I would shoot it with uro-prime and do a another final sand. Ray
  16. #15
    Village Mills, Texas
    I have a set from Dan Ruth that look nice. I can't post any pictures right now as they are packed for moving. As soon as I can locate them at the new house, I'll slip them on and post pictures.
  17. Likes JimLev liked this post
  18. #16
    Jun 2018
    Quote Originally Posted by HVACMAN View Post
    Cool. Roughly how much coverage do they give front to back?
  19. #17
    They are ~28 inches long and pretty much cover the flat area of the door sill. You can get them with a custom design if you want.
  20. #18
    Falmouth, MA
    How do I contact Dan Ruth? I'd be interested in a set for my car. I made some but they don't have a great "finished" look.
  21. #19
    Jun 2018
    Quote Originally Posted by cob427sc View Post
    http://www.innovativerodding.com/parts-services-2018/
  22. #20
    Falmouth, MA
    Thanks for the contact info. Their website is currently unavailable to show their products so I have emailed an inquiry about the sill covers,
  23. #21
    Jun 2018
    Hmmm works fine for me right now. I've heard he responds better to calls than email - 602 332-5398
  24. #22
    Placitas, NM
    Works for me.
    Pic of the sill covers....
  25. #23
    Senior Member JOP33's Avatar
    Haslet, Texas
    I actually made some as well from polished stainless, they look amazing until they don't and they are in an area that gets a lot of traffic. I opted to spray the area with a Raptor Guard product. It wears good and still looks clean.
