0
0
Originally Posted by
Snakeskin347
OK, I'll put them back in then... what is a nutsert? are they those rubber nut things that expand when tightened? I'm just thinking of tapping the frame with a 10/32 tap and using some stainless hardware that I had kicking around. It doesn't seem like it will be stressed very much so I think that would work?
Nutserts are threaded inserts that are similar to rubber “wellnuts” that a lot of motorcycle mfg. use. The inserts are installed by using a special puller to expand the nutsert in a drilled hole. They’re readily available from amazon at a fairly cheap price.
