Brandon,
Your second photo shows the UCA on top of the mount tabs. Just in case... it should be between the upper and lower tabs.
BTW stuff on the threads could be previous thread locking compound, maybe a pre-apply. I would clean the threads and use Loctite.
FWIW I find the R & L box sections at the corners of my "S" footwells too big to be effective dead pedals.
Reason: addl'
J R Jones
Yes, but the R mounts the UCA on top of the tabs and uses a spacer or washer stack to fill the tabs. Then you need to use longer grade 8 bolts for the new required length.
