0
0
'04 Fuel tank sender resistance
Is there anyone who has the '04 fuel pump tank (not installed yet) that can do me a favor and measure the sender resistance readings for full and empty? I made myself a note years ago that shows 255 ohms empty and 42 ohms full....which seems to be opposite of everything else I see where the empty resistance is lower than the full resistance....so just making sure I don't have that screwed up. Assuming you have an un-installed empty tank, you should be able to get the full reading by just setting the tank upside-down so the float falls to the top of the tank. Thanks!
Shane Vacek
VRaptor SpeedWorks, LLC
www.vraptorspeedworks.com
- You may not post replies
- You may not edit your posts
Forum Rules
