How To Aline Hinges and door question
So I have my doors trimmed and fitted into their spaces. I have the crash bar , latch and door hinges mounted in the door. I have the tee brackets mounted on the frame. I have the slots cut in the body for the hinge half that is mounted on the body. So my question. if I mount the hinge half on the tee bracket and leave that hinge and the tee bracket loose. then put the door in place run a 1/4" drill rod thru both hinges and then tighten up the tee bracket and hinge will that get me close to fitting?
If your luck is better than mine was, it should be a decent start…
A lot will depend on how flush you have the vertical face of the front crash beam sitting to the inside of the door.
That issue seems have caused a ‘gift’ on my truck that keeps on giving…I’ll swear on a stack of FFR assembly guides that my doors, particularly pass side, are twisting again. 😡
Good luck!
As you tighten everything you (in my case) will get creep - loosen here, tighten there, overcorrect a bit to compensate for the creep, rinse and repeat.
My doors are fitting pretty well now but the windows seem to be on a different plane than the opening
Super Moderator
Before embarking on such an endeavor, most builders say an appropriately edited version of the following:
"Recommended procedure before taking on a repair of Lucas equipment: Check the position of the stars, kill a chicken and walk three times clockwise around your car chanting:" Oh mighty Prince of Darkness protect your unworthy servant.."
Ray
