0
0
Originally Posted by
mmaragos
I just got through the registration for my GTM (I was #276 on the SB100 program for 2013). Not sure if it was mentioned here, but under the SB100 program you actually choose if your car is smog 'judged' by the engine year of production or the body year of production. If you decide to judge on the body and the body is not similar or a replica to a production car, the year assigned is 1960 - then all you need is a PCV valve / system.
When the referee asked me if I wanted the car judged by engine year or body year and I responded with "by body year" - he said "good choice".
Thanks for the first-hand info, and congrats on the GTM! That's my plan, and it's the way the law is worded. It just feels like a loop-hole, and I can't help but worry that an unsympathetic referee would be of the opinion that since the body is unrecognizable, it should be classified by engine. It sounds like I shouldn't be worried, though, and can plan on removing the air pump, evap purge valve, etc...
