Results 1 to 3 of 3
Thread: cutting 5/8 in off brake masters rod
    Saline, Mi
    instructions have u cut 5/8 in off ea of the brake masters, then assemble. Problem is you need the 5/8 u cut off to reach the coupler between the 2.
    Now I have 2 trashed brake masters???
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    This is one of those areas where the FFR manual could be improved. It's best to fit them up and then trim as needed, a little bit at a time. The good news is you can buy a rebuild kit for the MC relatively inexpensively (~$26 at Summit) that includes a new pushrod.
  3. Likes FF33rod liked this post
    When I cut mine I still threaded them to the bottom. Can you post pics?
    https://thefactoryfiveforum.com/show...tures-in-posts
    You should get to know the pic gallery, and use it to include images when you post questions. It gives clarity to what you are asking about (I'm a visual guy).
    HTH,
