0
33 street rod rear suspension hang
I have the Factory Five 33 street rod, no fenders, Blueprint SBC 383 with the TKX transmission. I got with the kit the 8.8 Moser rear end with the 4 link suspension. My wheels have not arrived yet so the chassis is suspended on a lift. My question is this-the rear end hangs low, if I raise it up and hookup my drive shaft it bottoms out on the tunnel and I dont want that weight/load put on the driveshaft. Is this normal or right? I have double checked the shocks and the way they are mounted and everything appears to match up with the manual but it just does not seem right. The problem goes away when the car is sitting on wheels and tires but what if I have to jack the car up for some reason, the drive shaft will bottom out on the tunnel/floorpan!! Am I missing something?
- You may not post replies
- You may not edit your posts
Forum Rules
