Building: Type 65 Coupe #385, Gen 3 Coyote & TKX
Ordered: 12/06/2021
Received: 8/15/2022
Build Update Videos
Build Photos
In the build manual, it says the 3 sheet metal parts that go on AFTER the body are the 2 cockpit corners (the pieces that tuck into the outer corners behind the seats with the pointy tops) and the vertical tail fin at the back of the trunk. The side panels that go along the trunk can be riveted in before the body goes on.
I'm also using a TXK (paired to a 302) and also cut away the cross-brace so I could mount the shifter in the rear. I'm making my own gear lever that will angle forward like the old Cobras. I dislike the short vertical shifter in the Daytonas.
Actually, there are a bunch more parts than that added after the body goes on. So many I made a list along with the page number in the manual. My manual is REVISION 4B, which is a couple years old. Suspect there's a newer one now. Maybe they changed the sequence on those side panels. A number of builders have commented they can be installed before the body is put on. I didn't try and it was easy enough to add them later. Builder's choice.
19. Hatch side aluminum (with bulb seal) lower flange goes under the floor aluminum, side panel touches the side of the floor (480)
20. Firewall extension (with bulb seal) (486)
21. Inner firewall extension (with bulb seal) (487)
22. Cockpit outside corners (with bulb seal) (488)
23. Outside nose mount cover (489)
24. Inside shock tower cover (490)
25. Fuel tank access covers (491)
26. Hatch area rear wall (with bulb seal) (492)
27. Aluminum Splash guards Front wheel, rear inside (512)
28. Front wheel rear (514)
29. Front upper splash panels (with bulb seal) (514)
30. Rear wheel splash panels rear (with bulb seal) (515)
31. Rear wheel splash panels front (with bulb seal) (not in manual, added part)
Scott Pregont
My Albums
Ordered: 12/06/2021
Received: 8/15/2022
Build Update Videos
Build Photos
I ordered a digital copy of the Coupe manual on 11/27/2021 and received Revision 4R, April 2021. When I received my kit on 8/15/2022 it came with the older version, Revision 4Q, October 2020. I suppose they had a bunch of them already printed up so I got the older version (4R), even though it had been updated with a newer version (4Q) 18 months prior.
Of course, you probably wouldn't want a manual that is a lot newer than your kit since things change with the kit (this is the opposite of my situation). I imagine they update the digital copy more often than the paper copy, which is logical.
Just to make sure I have the latest version I just purchased the digital version again just now and received the same Revision 4R that I purchased back on 11/27/2021. I will do a comparison of 4Q and 4R to make sure I am following instructions more appropriate for my kit.
Ordered: 12/06/2021
Received: 8/15/2022
Build Update Videos
Build Photos
Scott Pregont
My Albums
Manual revision 4Q is an abbreviation for F*** you where I come from. I wonder if it was printed April 1st?
Gen1 Coyote / TKO600 / IRS
Scott Pregont
My Albums
Ordered: 12/06/2021
Received: 8/15/2022
Build Update Videos
Build Photos
Quick question about reverse lights.
I have a TKX transmission. I am planning on using LED backup lights. I will be purchasing the backup harness that attaches to the transmission. Am I correct that I need to power either side of the TKS reverse switch. From there to the backup light(s) then to chassis ground. Because I'm going to use LED do I have to add anything to the circuit?
Scott Pregont
My Albums
Check the input voltage for the backup lights. If they are 12V, then the lights already have a ballast resistor in the path. If the voltage is less than 12V, you will need to install a ballast resistor.
Pretty sure aftermarket LED systems used in the automotive field already have a built-in ballast resistor, but if the ones you are using do not, then you will need to calculate the ohms for the ballast resistor and install it. For that you will need the voltage and current requirements of the LED. Use the following formula to calculate the correct resistor value.
Where:
V = supply voltage.
VL = LED voltage requirement.
I = LED current requirement.
R = ballast resistor value.
R = (V - VL)/I
If a ballast resistor of the above calculated size is not available, use the next largest resistor size. Do not use a smaller resistor or you will cut the life of the LED by a substantial amount.
Scott Pregont
My Albums
You need to confirm your LED backup lights are rated for 12V input (likely). If so, no resistors required. You should also confirm the current draw. As per most LED's, likely very low so nothing really special required to wire. I have two Watsons Streetworks L96WCL white LED backup lights (Maxxima brand) on my Coupe and power them with the RF panel 10 amp radio circuit. They only draw a fraction of that. The switch on the TKX appears to be the same one as on my T56. Closed when the transmission is in reverse. Open the rest of the time. I extended the ignition switched and fused +12V radio circuit wire to one side of the switch. Extended the other side to the back where it's connected to the plus side of the two LED lights. The other sides grounded. Circuit is closed when in reverse which switches on the lights. Simple and has worked fine for the several years it's been on the road.
I didn't find then -- and can't find now -- any description of the current limits for the switch in the trans. You could put a relay in the circuit. The GM automatic transmission in my truck build very specifically said not to power the backup lights through the switch and that a relay was required. Which is what I did. But don't think that's necessary in this case with LED's. Some also switch the ground side. That's possible too. But suggest keeping it simple as I described. It works.
Scott Pregont
My Albums
Had a delivery form FF today!!
Scott Pregont
My Albums
Nice! I have a package due tomorrow. I bet it's the same thing. I wonder why they ship those with 4 bolt flange adapters.
Scott Pregont
My Albums
Scott Pregont
My Albums
Day 135
Been working all week to prepare for first start. Verified the Sniper is live and controlling both the fuel pump and the fan. Verified that the engine will turn over when the key is turned to the start position. Plumed and filled radiator. Plumed and filled power steering. Added 5 gallons of gas to tank. No leaks so far. 50-60 PSI of fuel pressure at the Sniper inlet. Clutch safety switch works. Using the keyed ignition switch for now. Will switch to the DGD later. No go-kart as I'm waiting for my throttle linkage. Due next week maybe. A number of Upstate Cobra Club members will be joining me today. Big day!!
Had our own car show today!
Scott Pregont
My Albums
First Start try 1
FAILED!!! The engine turned over but we had no spark. After testing a number of connections and numerous discussions we realized that the coil had no power going to the positive terminal. That's on me as a newbe. I don't know what I don't know. There was nothing in the Sniper installation manual nor the RF manual that stated a power wire needed to be attached to the positive side of the coil. We attached a jumper wire from the orange ignition wire on the key switch to the positive side of the coil.
First Start try 2
How sweet it is. Two small water leaks that stopped themselves. Brought the temp to 195 and the fan kicked in and the temp came right back down. Milestone accomplished!! Thanks to the group for their aid is making this happen!!
Scott Pregont
My Albums
My slow internet connection won’t let me see the video but I believe ya’ when you say it ran! Big time congratulations on the milestone Scott
Scott Pregont
My Albums
Very nice! Congratulations.
Looks and sounds amazing, congratulations! I can't wait to get mine to that stage, you are way ahead of me. I just got my hardware pack and have not been able to really do anything but sheet metal.
Sounds and looks great Scott! Congratulations!
Scott Pregont
My Albums
Scott Pregont
My Albums
Congrats, Scott! That's music to my ears. Big milestone reached.
Coupe complete kit. Index. Delivered: 4/22/24. Build Thread. Coyote Gen 4X. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
Scott Pregont
My Albums
Congratulations! During a build there are always moments of satisfaction, but I do not think anything compares to the first successful firing up of the engine. Well done Sir, well done.
Last edited by Skuzzy; 11-07-2022 at 08:14 AM. Reason: Bad grammer...otherwise known as too much beer.
Thank you Sir! You are correct. I went into this not knowing if I would be able to accomplish it or end up having it sit in my garage unfinished because it was beyond me. Hearing that engine start gave me such pride in myself and gave me the confidence that I will complete this build.
I had a local coupe builder stop by to check out the progress and his posted comment was "Had a chance to get out for a while today. Stopped by Scott's. All I can say is WOW. I've seen a bunch of builds but this one is world class. No expense spared. all the bells and whistles, all meticulously assembled." To hear that kind of praise is so very satisfying and very humbling.
Scott Pregont
My Albums
This will be project #43 for me and my first Factory Five, as well as the third personal project. I can tell you that first engine start still feels like it did when I did the first project. I thought this would be my last project, but Factory Five went and stretched the 35 Truck, and the Wife is not going to rest until I get that built for her. So #44 will be the last.
At nearly 70 years old, it is time to enjoy the fruits of my labor.
Courtesy Lights
Continuing my wiring brings me to my courtesy lights. I pulled out the FF supplied LED strip and was not very impressed at first glance. I have been looking at what others have used but until I get the A/C - heater installed I'm not sure where to mount anything. Decided to cut the FF strip in half and to mount it figuring I can replace it at a later time. I have to say I am very surprised and impressed at the amount of light given off by this small strip. May just leave it!
DS
PS
Scott Pregont
My Albums
Decided to mount the trunk panel today. Siliconed all surfaces and laid the panel in place. Grabbed the Milwaukee M12 battery riveter (that's less than a year old). After a hand full of rivets the battery went dead. Grabbed the fresh battery from the charger and lo and behold it was also dead. No lights on the charger. Nothing. Have no idea what happened to the charger. Ran to the local Ace and bought a Channel Lock hand riveter. Worked fine except for the arthritis in my hands.
Scott Pregont
My Albums
Scott, do you need an M12 charger? I have an extra, happy to send it. Save those thumb joints brother.
Scott Pregont
My Albums
One for the electrical experts
The RF electrical installation manual shows cutting the relay wire for the fuel pump if using EFI.
I have not done this. As seen in my recent first start video the engine started and ran fine. Is cutting this wire a requirement and if I don't cut it what do I risk?
Scott Pregont
My Albums
