Thanks Thanks:  8
Likes Likes:  36
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 87
Thread: Chris’ Daytona Build
    Senior Member rhk118's Avatar
    Nov 2021
    Portland, Maine
    I am really liking the idea of a rearview mirror / camera setup @rsnake mentioned above. Going to research those more. Trick like he mentioned will be placing the camera in a location where it isn't too visible. My main concern I guess is someone coming quickly up on you into the blind spot....I imagine especially with these cars guys speeding up from behind to "check it out" (guilty of that myself )...and being harnessed in difficult to manually check the blind spot I imagine...
    Wonder if it can just be mounted inside to the hatch glass up top....distortion for sure, but I don't need to be able to read what brand of chips they're eating
  2. Likes cgundermann liked this post
  3. #42
    Chino Valley, Arizona
    Well the beauty of this is that I bought it from Costco, so if I don't like, I can return. Unfortunately, the camera is mounted in the license plate - lower which is not the ideal location as others have mentioned. The monitor can be mounted as a rear view mirror and you can adjust the field of view, so I'll give it a try.
  4. #43
    Spending money like a Rockstar, ordered the PBS-1 push button start from Digital Guard Dawg.
    Screenshot_20220206-162932_Samsung Internet.jpgScreenshot_20220206-163033_Samsung Internet.jpg
    Requested the black billet aluminum start button (over the brushed stainless steel) with the GREEN halo activation/arming light which will go nicely with my green Speedhut gauges. Also chose the standard key fob over the OEM style. This allows for you to slide the fob open and turn off the proximity arming feature for example, if you are at a car show.
  5. #44
    May 2019
    Quote Originally Posted by cgundermann View Post
    I'm sure you could use some other camera besides the one it comes with.
    Or, mount the license plate on top of the car!
  6. Likes cgundermann liked this post
  7. #45
    Oct 2021
    Quote Originally Posted by Dave Tabor View Post
    Ninja or CBR mirrors from Amazon.
    I ordered 818 mirrors for my coupe, which are similar to all the mirrors mentioned in this thread (at least from the pictures). My shipping date is in July though, surely somebody tried these and i will not be the first one?! They are out of stock now btw..
  8. #46
    Senior Member Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    Chris,
    Congratulations, not on the forum much. This is the first time reading that you ordered a coupe kit. Sounds like it going to be an awesome build. The coyote comes on strong in the mid range rpm’s. Can’t wait to see it come together.
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
  9. Likes cgundermann liked this post
  10. #47
    Hi Paul, thanks - appreciate it my friend. I'm looking forward to seeing how the Gen 3 Coyote performs. Hopefully, the weather up there is changing so you and the gang can get out for some group runs! I do miss those...
  11. #48
    More parts acquired - windshield wiper motor from Speciality Power Windows & windshield washer fluid container/pump from Chase Bays.
  12. #49
    May 2019
    That washer bottle doesn't hold much fluid, huh?
  13. #50
    Quote Originally Posted by Ltngdrvr View Post
    No, EdwardB forewarned me. Didn’t really want a plastic one, not like I’ll be using it a lot. I am impressed with the quality of the unit….
  14. Thanks edwardb thanked for this post
  15. #51
    FFR Maven Logan's Avatar
    Huntsville, AL
    Chase Bays parts are very nice quality, I have their hydro in my Coupe-R. Their shop is in Birmingham Alabama, about an hour south of me.
    You don't need much volume for washer fluid. Not like a daily driver mule with 2 gallons. I'm curious to see how you tackle mounting the spray nozzles to the body, or integrating them to the wiper arms.
    Logan's Gen 3 Coupe-R Build
  16. #52
    I’ll keep you posted Logan.
  17. #53
    Received my Gen 3 Coyote from Forte today. It has the Ford control pack, alternator & additionally, a IRS diff vent kit for the rear end I recently bought from him. I also had previously received my TKX transmission & hydraulic throw out bearing from American Powertrain:
    IMG-1373.jpgIMG-1371.jpgIMG-1370.jpgA04EDA80-122F-49FC-859B-1508551981C2.jpgA7381B9E-B7D0-46A2-A87B-6AEDF6387FA3.jpg2EC59A1B-C465-42BD-8692-8CF18C1C1B77.jpg
  18. Likes rhk118 liked this post
  19. #54
    May 2019
    Received my Gen 3 Coyote from Forte today. It has the Ford control pack, alternator & additionally, a IRS diff vent kit for the rear end I recently bought from him. I also had previously received my TKZ transmission & hydraulic throw out bearing from American Powertrain:
    TKZ trans???
    Do you mean TKX?
    What flywheel and clutch do you plan on?
  20. #55
    TKZ trans???
    Do you mean TKX?
    Yes, TKX...old eyes. Going to purchase my flywheel from American Powetrain (been real impressed with them so far), and going with the new high reving/horse power Centerforce clutch for the Coyote.
  21. #56
    And so it begins! This morning, Stewart Transportation delivered my Type 65 complete kit #151885. The same driver delivered my MK4 Cobra to Washington State 12 years ago. It never gets old...
    IMG-1389.jpgIMG-1383.jpgIMG-1382.jpgIMG-1384.jpgIMG-1391.jpgIMG-1393.jpgIMG-1394.jpgIMG-1395.jpgIMG-1397.jpgIMG-1396.jpg
  22. Likes rhk118, JimStone liked this post
  23. #57
    May 2019
    Hey, none of the pic attachments work...
  24. #58
    I reloaded them, the orientations are off as well - it's acting goofy when I attach pics...
  25. #59
    May 2019
    Load them as images instead of attachments, don't use the photo tag at the top of the post, wrap the image adressess in [IMG] and [/IMG] tags.
    Of course that only works if you have them posted at a photo hosting site...
  26. Thanks cgundermann thanked for this post
  27. #60
    Nov 2021
    Portland, Maine
    Congrats Chris! Let the fun begin.
  28. Thanks cgundermann thanked for this post
  29. #61
    Quote Originally Posted by rhk118 View Post
    Thank you!
  30. Likes rhk118 liked this post
  31. #62
    Precursory inventory done. Many items pending and body removed. Coyote Moroso race/low profile oil pan ordered (unknown ETA, but Moroso oil pan pickup received). Alignment/overlap - Sharpie marking & numbering of aluminum panels next...
    After that, photos and removal of aluminum panels.
  32. #63
    May 2019
    A portable building for your garage, huh?
    How much weight is the floor in that thing rated for?
  33. #64
    Left my big shop in Havasu for my ranch. Have three separate out buildings and a three car garage. It can can handle way more than this light car. Miss my big shop, but, - this is fine…
    I will use my big garage to drop the motor in. This building is exclusively for the build. I've worked with less...
  34. #65
    May 2019
    Left my big shop in Havasu for my ranch. Have three separate out buildings and a three car garage. It can can handle way more than this light car. Miss my big shop, but - this is fine…
    Just curious, have thought of getting one of those buildings a few times over the years.
  35. Likes cgundermann liked this post
  36. #66
    All 34 panels mounted by FFR with sheet metal screws, numbered, Sharpie marked all overlapping/adjacent panels to show interface & photographed prior to removal.
  37. #67
    Unfortunately, had two surgeries on my right arm and battling an infection at one of the incision sites. I did get the steering rack mounted and sent my steering hub off to Russ Thompson for his modification for his turn signal assembly:
  38. Likes rhk118 liked this post
  39. #68
    Taking advantage of healing down time and ordered the remaining components for my drive train. Forte received a pallet of Coyote Moroso oil pans today, so I canceled my pending Summit Racing order and purchased from him. Additionally, ordered the remained needed components: starter, Quick Time Bell housing, fly wheel, clutch, clutch fork and all needed hardware & gaskets. Did not know, but Quick Time makes two different bell housings for the Coyote, street & race (SFI rated). Forte has a large industrial band saw that makes quick work at clearancing the bell housing to clear the frame. As most have commented, the Gen 3 ain't pretty to look at and the engine cover requires modification to work with this application. Forte modifys a Gen 2 (I believe) engine cover to work with the Gen 3. The heads & coil packs are exposed, but it's an improvement, so I ordered that as well:
  40. Likes Chopper, rhk118 liked this post
  41. #69
    Nov 2021
    Portland, Maine
    Looks awesome Chris! I often question my going with a 347 when seeing these Coyotes....
  42. Thanks cgundermann thanked for this post
  43. #70
    Thanks Richard, I went kicking & screaming with the Coyote (better half & son wanted it). Very happy with my 347 and maybe just a bit intimated by the complexity of the Gen 3. But, it will pay off in the long run. Performance, cost, drivability, mileage etc…
    The simplicity, performance and the vintage look of the 347 is hard to beat. Ironically, I spent less on my Gen 3 Coyote than I did on my 347.
  44. Likes rhk118 liked this post
  45. #71
    Nov 2021
    Portland, Maine
    Well I'm building a 347, and I don't think you're being ironic at all! I have come to find the parts shortages as a bit of a needed "payment plan" haha...
  46. Likes cgundermann liked this post
  47. #72
    Yes, so true LOL…
  48. #73
    Well, after a number of medical procedures and my son's wedding in WA State, back at it. Lower control arms (rear spacer installed) and Moog tie rods used:
  49. Likes rhk118 liked this post
  50. #74
    Nov 2021
    Portland, Maine
    Great to see you back Chris!
  51. Likes cgundermann liked this post
  52. #75
    Thanks Bud!
  53. #76
    After several inquiries from our community, I felt compelled to explain why this build is starting slow. After several right arm surgeries and a bad infection at one of the surgery sites, I'm still struggling with the functioning of my right hand. I'm also battling vertigo as well from previous cervical fractures & surgeries. So I'm taking advantage of this down time to have a steel shop put up. You don't realize how dependent you are for day to day activities in using your dominant hand. Things are compounded by my balance getting turned upside down.
    Just wanted to let my extended family within our great community know, that I'm slowly moving onward & upward.
  54. Likes JimStone liked this post
  55. #77
    May 2021
    Fort Worth, Texas
    Hope things heal well and you are back to normal soon. Good luck!
  56. #78
    Thanks my friend.
  57. #79
    Front coilovers and lower control arms installed after the springs were re-coated in red powdercoat to match the red Wilwood calipers. I believe other members have noted this, but the stainless steel bushings that center the upper shock mounts are not clearenced enough for the attaching bolts to pass through. Do not try to "deadblow" the bolt to push through these sleeves (how do I know?). It will deform the mounting tabs very easily...used a pricy drill bit capable of reaming through the stainless steel mounting spacers to the bolt's specific diameter.
    Between health challenges and putting up a new shop, this is going to be a much slower build than originally planned.
  58. #80
    I wanted to reach back out to the community I have been involved with and have loved over the past 11+ years. Still have been off radar and uninvolved for months...
    Multiple surgeries, infections, setbacks, weddings, construction projects...it has been a tough fight.
    We get to a stage in life to obtain our personal dreams, yet our chosen paths in life and the physical trauma associated negates the joy. Do your best to protect your body!
    My complete respect to our members that are building while battling serious health challenges. There is a fine line where the joy of building offsets physical pain...
    Hope to building soon. Have written a lot of checks that I can't currently cash (CNC Plasma table)...
  59. Likes JimStone liked this post
