Likes Likes:  4
Results 1 to 15 of 15
Thread: 33HR bicycle fenders
    Falmouth, MA
    Anyone know if FFR still makes the bicycle fenders available that are not carbon fiber? Nothing is listed in their parts section other than the carbon fiber. Since these are going to be painted, I hate to spend the extra $$$ for carbon fiber.
    Jun 2018
    North Vancouver, BC, Canada
    I heard that they don't as the cost difference wasn't enough to justify carrying both.
    Gen 1 '33 Hot Rod #1104
    Oct 2021
    Curtice, Oh
    I wanted to order them and was told exactly that. So I will make my own front fenders for a lot less. Ideas I have kicked around is use some reproduction rear fiberglass fenders from an old truck and alter them. Another is to just use some metal trailer fenders. Or just make a mold out of wood and lay fiberglass. Lot of examples of people making motorcycle fenders out there.
    Since it will be quite a while before I even get the kit, my first step is hit a bunch of swap meets in the spring and see what pops up.
    Jun 2020
    SoDak
    Quote Originally Posted by Jeff33Ford View Post
    Speedway Motors and some other places sell bike fenders for hot rods that may work too.
    Jim
    Jun 2018
    Don't forget that Dan Ruth (Innovative Rodding) has a high quality fender set for the hot rod.
    https://www.innovativerodding.com/parts-services-2018/
    Oct 2021
    Curtice, Oh
    I see Fenders but not bicycle fenders, at least on their site.
    Jim
    Maybe I am not searching correctly but I cannot find any that could be used. Some kind of look like the right type but are too narrow.
    Falmouth, MA
    Front fenders are not such an issue to modify from whats available, but rear fenders need to be fabricated to fit the body along with the front mounting brackets. Seems to me the original glass fenders from FFR started at around $600/set but now are double in the carbon fiber material.
    Jun 2018
    I believe he has the bicycle fenders too, give him a call, very helpful guy
    Simi Valley, CA
    If anyone is interested, I have a set of FFR front fenders and running boards for the Gen 1 '33. I used parts from another vendor, so the FFR stuff is just collecting dust in my garage. PM me if interested and we'll work something out.
    Keith HR #894
  10. Likes FF33rod liked this post
  11. #10
    Nov 2021
    I have a spare set of fenders......Front, running boards and rear.......unfortunately, the bike fenders went with car......I think the rear fenders are the same.....Call me if interested Silversnake.....607423-1608
  12. #11
    Nov 2021
    I have a full fender set, fboth front fenders, both running boards, and both rear fenders.........could you modify these to work? All painted (high quality work) gloss black.....call me, Bobtail Builder...........607 423-1608 ...located in NY.
  13. #12
    Falmouth, MA
    Seems like lots of full fenders available but nobody has the bicycle fenders. I couldn't find any bicycle fenders on the Ruth website but I will give them a call. I wasn't going to run any fenders at all but after driving through a couple of puddles and finally getting hit in the cheek by a thrown rock I've changed my mind.
  14. Likes FF33rod liked this post
  15. #13
    Jan 2016
    Bike fenders
    I think Dan Ruth might still be selling his versions of the bike fenders; sheet metal fronts
    And glass rears. Check out innovativerodding.com
    Good luck
  16. #14
    Seasoned Citizen NAZ's Avatar
    If you can't find what you need, consider fabricating some custom bike fenders. It's not that difficult and if you can't weld, there are shops out there that can handle that for you. I couldn't find store-bought fenders when I went with skinny front runners so I cut up a Harley rear fender to make a pair.
  17. Likes HVACMAN liked this post
  18. #15
    Mar 2018
    I have the bike fenders that are carbon fiber. So with the finish of the carbon fiber bike fenders I am not painting them. They look absolutely flawless. However, you could paint them. But who paints over show quality carbon fiber LOL
  19. Likes shmelty liked this post
