B Campbell
I see your going to add the Wilwood remote balance bar adjuster. what side of the balance bar are you thinking of connecting the adjustment cable? I`m mocking mine up now and if I connect to the Drivers side of the bar it looks like it will interfere with the top of the clutch pedal. the Engine bay side seems to be ok but the cable housing looks like it may contact a frame bracket on that side during the pedal travel.
I have it on the left side. I am lifting it just a smidgen (via zip tie). I do not believe there will be any interference
