110
Serenity
Thank you! I've enjoyed following your build and different threads. You've had quite the experience and I've learned a lot just by following your threads...
Take a look at Edwardb's (Sir Paul B.) two MK-4 build threads and you'll see how things really should be done.
Any advice given to you by Mr. Paul, 65 Cobra Dude, Erik Treves, or Jeff Kleiner is advice worth taking.
Good Luck & Happy Wrenching!
GoDadGo
Thank you! Yes, I have so much respect for you as well as the other's you mentioned. I've been following Edwardb's build thread, and it has been helpful. I probably shouldn't have installed the rear upper/ lower control arms until I installed the rear differential, but I'm a glutton for punishment. I'll stick to primarily working on the aluminum until I get more parts...
