Likes Likes:  6
Thread: Side exhaust question
    Senior Member zee's Avatar
    Dec 2021
    I love the 289 body shape. But I ordered a MKIV because the only quiet pipe options that are still available are from Gas-n. I am not competent enough to weld something myself.
    Here's a question for all y'alls: I assume that I can just make a cut on the side of the 289 body and use 427 headers+exhaust? I know it's not a correct look, but I just want to check that it's as simple as that.
    Thanks.
    Complete novice who doesn't know what he's doing.
    MKIV with BPE 347 & TKX. IRS. A crap ton of mods.
    Build thread
    Mk4 and 289 chassis are the same so the 427 pipes should work.
  3. Thanks zee thanked for this post
    Likes Lickity-Split, cnutting liked this post
    Sep 2015
    Beachside
    I heard Bob Boig's products would be available through Tubular Automotive. Assume they would continue the 289 pipe production as well?
    FFR #8833 289 FIA 3-link
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    The best thing to do is call. Dan or Dave. 781-878-9875
    Scott Pregont
    My Albums
  6. Likes cnutting, mburger, zee liked this post
  7. #5
    Mar 2018
    If you want the pipes to look the same, a muffler shop should be able to modify and weld you side pipes up with baffles. You can purchase muffler baffles online. Not going to work as well as the gas'n pipes.
  8. Likes zee liked this post
