Sheet Metal Installation
Just a sanity check ...
Am I correct in believing that pretty much all sheet metal panels may be assembled to the chassis before the body is installed, EXCEPT rear splash guards, upper engine bay splash guards, front wheel rear splash guards, and the firewall extensions?
Yes and the rear vertical trunk section, leave it off or temporarily installed until after paint and the rear lights are installed.
Mkll 4874 built in 2004
I'd add the rear cockpit corners to the list. You'll have a hard time fitting the body around those. Plus the body placement kind of determines where they get installed. The manual says the hatch sides should be installed after the body is on. Which I followed and was OK. But several have commented they don't get in the way.
For the record, the build sequence in the manual explains when each panel should be installed. Basically in about five different build sections. Before and after the body is installed. I followed the sequence on mine and worked out OK.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Originally Posted by
edwardb
Well, to be honest, I have been out of sequence since about Day 2 (end of September) due to missing parts. All parts, save door latch cables, are now in my shop.
I am doing a reasonably thorough installation of sound dampening (of the stick-on variety), which is one reason I am thinking about completing at least interior aluminum panels. I am also considering most interior finish work in parallel with work on the fiberglass (while the body is off). Interior finish work with the body removed seems easier.
I note that both the hatch sides and cockpit rear corners were shipped to me as installed panels. So I am curious about your comment concerning the difficulty fitting the body around them. Time to buy a few more clecos, dry fit these panels and the body methinks :-)
Thanks all for the comments!
LateApex
I note that both the hatch sides and cockpit rear corners were shipped to me as installed panels. So I am curious about your comment concerning the difficulty fitting the body around them...
You don't think the guys at FF installed those panels after they dropped the body on? Especially the rear cockpit corners? I don't know if you removed them before you took the body off after delivery. I didn't. And they were bending and scraping the whole time. Made a mental note at the time to not put them back on until after the body was on for the last time. Then found the manual instructions that confirmed that assembly sequence. The hatch sides are less of an issue. But I still found it easier to drop the body on without them in place. I get that you're jumping around based on parts. I did too. But I'd still recommend searching the manual (easy to do with an electronic version) and note the sequence of when they show installing the various panels.
Build Thread and
Video.
Build Thread and
Video
edwardb
Actually no. I think the panels were affixed to the chassis (this required drilling which would be at best impossible with the body on where sheet metal screws were used, for example in the very rear corners, and why would panels be temporarily tacked like that only to be removed, then install and tack the body, and then re-attach the panels?)
Like you, I did not remove any of the installed sheet metal prior to removing the body. The manual does not suggest that either. I did not have any scraping and bending of the hatch sides or the cockpit rear corners. The hatch sides seem most vulnerable, as they protrude above the frame, but by sliding the body rearward after freeing the pontoons, I had no problems. The cockpit corners are completely masked by the frame - I am not sure how they would interfere with the body assembly / disassembly in any way. The hatch rear wall has been tweaked a bit. Probably my clumsiness when initially removing the body. But as David mentioned earlier in the thread, this needs to be installed after the body, if anything to enable taillight hookup.
I am wondering if there are differences in the sheet metal between your build and mine. I was surprised by the two-piece radiator duct back, which I posted a question about in a separate thread. THAT upper section I will not install until I have bonnet lined up.
I am a novice builder - ignorance is bliss :-)
LateApex
Maybe there are differences. Mine is serial number 59. I have the one-piece radiator back wall, for example. Plus received a box of modified panels several months after I received my kit. Whatever. You asked, I answered with my experience. Which is the only thing any of us can do. Up to you whether it fits your situation. Sounds like you have it all figured out. Good luck.
Build Thread and
Video.
Build Thread and
Video
