narly1
How do you find mounting position to be in terms of accessibility & protection?
I want mine to be in a spot where I can easily get at it to swap in a new pump if need be.
I think I would have no issue with the passenger rear wheel removed. I mounted it with 2 bolts through the frame so easy to remove as a unit if needed.
Post Thanks / Like - 1 Thanks, 4 Likes
