15
71
TxMike64
Could you share some pics of where you mounted the rear brake line brackets? Where the braided line connects to the hard line?
I have an idea where I want to mount mine, but wanted to see what others with the '15 IRS have done.
Thanks!
Sorry for the poor photos, but it was too hot to spend much time in the garage today. In any case, I riveted the brake line support brackets to the upper control arm mounting flange. This was a convenient location that allowed the flexible brake lines to move through the full range of travel without interference. The view in the photos is somewhat obscured by additional structure that I added, but I think you can get the idea. If it matters, I have the optional Wilwood brakes on a 2015 IRS in a Gen 1 Hot Rod.
HTH Keith HR #894
Consummate Learner
progmgr1
HTH Keith HR #894
That's helpful, Thanks!
