Thank you guys - appreciate the comments.
Spent a while today working on the CAD file. I started with the ideal situation matching the Ford rear end width of 59.75" hub to hub. That would give me the most flexibility with wheel selection, but it looks pretty tight in terms of making new chassis mounting. I was hoping to be able to use square tubing with simple mount flanges but I can get more elaborate if need be. I can also push it back out a bit too. It just means less dish on the wheels and likely custom backspacing.
I should receive the new lower control arms Thursday and will add them in once I get the part modeled.
Post Thanks / Like - 0 Thanks, 3 Likes
