Finally got time today to take the car over to the shop for TIG welding on the main battery box. Now I can tear it apart and work on the Cerakote. It takes a lot of media blast prep, cleaning, and 5 days to cure so it'll be a few weeks before I get it all back together. But, when it's done I'll be installing the batteries which will be a big step.
With the front box out I was finally able to fit check the transmission tunnel patch I designed and had made a couple of weeks ago. The bend aligns perfect with the firewall. Still need to drill holes and bolt it around the perimeter but it all lines up well.
And for almost a full week of spare time work - here's what I have to show for it. Did I mention before this is tedious?? I still have 4 more to go and then I have to make 40 thermocouples, attach them to the batteries, and make the harnesses. I have to admit I'm not enjoying this part as much. But it's necessary so no way around it.
Anyone complaining on wiring has got nothing on you. Crimp on!
Mastertech5
I think complaining about wiring is a universal right with any build. Ha..
