Thanks Fixit. I didn't even think about illuminating the cubby. (Slap to forehead). I bough two roles of LEDs so I can go crazy if need be. As for wiring I was running a 10ga always hot for other accessories and just tapped that for my trunk (possibly cubbie) light, USB power, and standard power port in the back. The front end of the circuit will get it's own fuse and run engine bay lighting, footbox vent fans, linelock, another USB powerport, and an additional standard power port. I did think of using the radio wiring but incase everything was running at once decided on a larger dedicated power supply. I also ran a 10ga for the Holley Sniper setup, so lots of direct battery power.
