20
40
Chopper
Hello and welcome. Looks like you're off to a good start with a very well optioned roadster.
I would recommend looking into a driveshaft loop (Forte sells one that fits the MKIV), or many other options (Summit, Jegs, etc), and also a SFI steel bellhousing. I believe Forte will cut them down to clear the frame rails (otherwise they hang below), or you can source separately and cut yourself with a metal bandsaw, angle grinder, etc.
One other thing to note is you will have to modify the glovebox on the dash in order for the heater to fit, or locate the heater differently than factory five's default location.
Agree about the driveshaft loop. I picked up a metco loop and installed on my rig. The idea of the driveshaft spinning right beside my lateral hip as well as the passenger unnerves me a bit. Really good folks here. I consider many my friends and they really want you to succeed.
FFR MK4 Roadster (9945) complete kit, delivered 12/4/2020, First start and go kart 5/7/2021. Legal 8/14/2021, Paint finished 7/18/2022 (Viking Blue). 347BPE CI, TKO600, Moser 8.8 3link 3.55, Halibrand 17x9 17x10.5, power steering. Carbon Fiber Dash. Carbon Fiber trans tunnel, adjustable Kirkey Lowback Vintage seats, Vintage gauges, RT drop trunk mod, FFmetal drop battery mod and trans tunnel, Forte front sway bar. Forte mechanical throttle linkage, RT gas pedal.
www.covespringsfarm.com
