0
0
Husband/father/son
Booth Rental agreement-follow up
This is the short agreement, simple and to the point. What do you guys think?
Bill S.
Booth Rental Agreement
Terms and Conditions:
This contract is for 1 eight (8) hour rental of the paint booth located within the building located at 90 MAACO street, Pottstown, PA.
You may bring up to two additional people to assist you with your masking, you as the renter will be responsible for their personal liability.
Payment of $1,000 in full to be made at time of arrival, terms are cash only, no personal checks or credit cards will be accepted.
Additional booth time (not including final overnight air cure time if so desired) will be charged at $150/hr
Car/truck/boat/etc will not be released until bill is paid in full
What is included in the rental:
Modern, heated air make up equipped paint booth, 10/15hp 200gallon dual air compressors, appropriate properly balanced and set up paint guns for primer/sealer, single stage, and/or base coat/clear coat paint systems. We will safely dispose of all thinners and paint waste (from paint mixing and paint gun use), we will clean all paint guns.
Safety Equipment:
A fresh air system is plumbed into booth, you will be responsible for supplying your own fresh air mask and air line. If you choose not to spend the money on a fresh air mask, air hose, and equipment, at a minimum, you (and your assistants) must have a 3M Dual Cartridge respirator (part # 07193) , and a disposable paint suit (available from paint supply houses like Finishmaster).
Paint supplies:
We will supply marked mixing cups, digital scale, marked mixing sticks only. You are responsible for bringing in your own paint supplies, which includes but not limited to thinners, reducers, primers, single stage or base colors, and clears. It is highly recommended that you contact your local paint supplier (AKA: like Finishmaster) and explain to them carefully what you are planning to do so they can assist you in determining how much material you will be using.
Liability:
You as the renter of said paint booth accept any and all liability for your own actions; as such you release BDJsilver LLC with prejudice from any and all liability.
Misc T’s & C’s:
All prep of the car should be done down to final sanding, no sanding will take place once the car is in the paint booth. BDJSilver reserves the right to remove you and/or your chosen assistants at will if it is believed they are acting in a manner which could place them in harms way. Misuse, abuse, theft, or destruction of shop equipment will not be tolerated. You break it, you are financially responsible for it, plain and simple.
- You may not post replies
- You may not edit your posts
Forum Rules
