0
0
New guy and possible 33 build
I've been looking at FFr for more than a few years. My friend built a MkII and I always wanted to build a GTM. Problem is, i'm 6' 270 and i'm afraid it would take a pit crew to get me up out of one. I'm now considering a '33 Roadster and will be asking a lot of stupid questions i'm sure. I am just finishing up going as far as i'm going to go for now on my '68 Camaro.
Here is the build sheet of what i've done with it.
My build sheet:
1968 CAMARO 124 code car
454ci - 6sp- 4 wheel disc
OWNER, BUILDER: ME
Block 361959 E11 78 (May 11 1978)
600hp/581tq 10.2:1 comp
Bullet Racing Camshaft
234 int/242 exh @ .050
.601 lift on a 106
Morel Hyd roller lifters 4603 $800
Comp Cams Ultra Pro Magnum Rocker Arms 1820-16
Wiseco PTS514A3 Pro Tru Pistons Hollow Dome .30 Over Bore $515
Brodix Cylinder Heads Race-Rite Oval Port 110cc BRO-2061006 $2500
Holley Stealth EFI
Holley 550-1001 - Holley Terminator X Stealth 4150 EFI Fuel Injection System
Holley 534-247 - Holley EFI Stealth 4150 Fuel Log
Holley 12-876 - Holley EFI Filter Regulator
Holley Sniper 19-401 - Holley Sniper EFI Conversion Fuel Tanks
Holley Sniper 565-300 - Holley Sniper EFI HyperSpark Distributor
Holley 558-323 - Holley Terminator EFI HyperSpark Ignition Adapter
Holley Hyperspark box 556-151
Eldebrock RPM Air Gap Intake 7561
Hooker Blackheart stainless headers # BH13181 $1200
Flowmaster mufflers
Autotrend EFI - Billet Plug Wire Looms $160
Concept One Victory polished serpentine pulley system (reverse rotation water pump) $2800
Cold Case big block radiator, 2 row 1.25” tubes $350
Wizard Cooling Duel 12” Spal Brushless fans controlled by the Holley ECU
AutoPlumb -20AN upper hose
Fessler radiator core supports $200
Tremec T56 TUET 11009 2.66 1.78 1.30 1.00 .80 .63
McCloud dual friction clutch
QuickTime Bellhousing
Red Roberts Shifter
Hurst Billet Aluminum shifter arm
Wilwood Hyd Clutch master
Front Suspension:
Tubular upper and lower control arms
Viking Warrior double adjustable coil overs
DSE 1.125 Swaybar
ProForged tall upper ball joints, tie-rods, idler arm, pittman arm, centerlink, lower ball joints
AGR Quick ratio 12:1 P/S gearbox # 492117
Eddie Motorsports Gen II P/S pump
Turn 1 remote P/S reservoir
Derale P/S cooler
Hotchkis Handlebars
Rear suspension - Ridetech Triangulated 4 link - double “R” joints
Ridetech Coilovers (lifetime warranty)
DSE HD Spring pockets DSR-040110
DSE mini tubs
Dakota DIGITAL VFD instrumentation w/integrated GPS speed sender
Vintage Air A/C system w/integrated climate control
DSE Firewall delete panel
Ididit tilt steering column
MOMO MIL35BK1P Millenium 350 mm Leather steering wheel
Sony 7” touch screen stereo
Odyssey Trunk mounted Drycell AGM battery, remote solenoid and Master cutoff
Retro-Electro electric headlight door kit
Phillips H6024LED headlights $290
4” LED strip front turn signals
Raingear Hidden wiper motor system raingearwipers.com
BMR Solid body mounts
BMR subframe connectors
Billet Specialties Gas Pedal assy and brake/clutch pedal pads
Lokar Throttle cable
Ridetech Billet aluminum locking gas cap and filler neck
Rear brakes 2015 Camaro V6 LT (bigbrakeupgrade.com)
Front brake pads # D52
Moser built 12 bolt, narrowed 6” 54.75” axle face to axle face
3:55 gears, Ford Big bearing ends, Moser cover, Eaton posi unit, 1350 u joint
Rims - Intro Design 5 spoke Endless
Front 18x8 4.5 backspace / Rear 19x12 5.75 backspace
Michelin PILOT SPORT 4S front 255/40-18 rear 325/30-19
Anvil fiberglass radiator close out panel
Anvil fiberglass wiper cowl
TMI one piece headline, a pillar covers and sail panels
Corbeau LG1 wide seats
ACC Essex carpet
Eddie Motorsports Billet door sills
20220825_183305 by F G, on Flickr
20210514_173950 by F G, on Flickr
20210514_174912 by F G, on Flickr
20210514_175245 by F G, on Flickr
- You may not post replies
- You may not edit your posts
Forum Rules
