Power steering controller location?
I find that the suggested location for the PS controller on the upper dash frame bar and suggested harness routing do not leave enough length in the 2 extensions that plug in near the motor to plug them in. I remember reading a post where this was discussed but I can't find it. There was something about extension harnesses. I was wondering what others may have done in this situation or where you guys have mounted the controller.
I mounted the PS controller on the right side of the bracket that holds the brake master cylinders.
You’ll need to extend the wires, cut and splice them to make them longer to reach the controller.
Originally Posted by
JimLev
I figured I'd have to extend the wires. That was obvious when I tried to find a place to mount the controller. I think stuff like that should be taken into consideration by FFR when writing the manual and by giving you long enough harnesses to reach the place they suggest to install the controller. Not a big deal for me but not everyone is adept to doing that sort of thing. I thought someone might have found a place to mount it inside without having to extend the harnesses. Thanks for chiming in!
Bruce
Mastertech5
Bruce
Therein lies the problem with most people who buy these kits cars. They assume a "kit car" is nothing more than a giant Lego set so everything will fit together perfectly and the manual is rock solid. The manual is just guide, nothing more, nothing less. The first few pages of the manual note in several places that the manual is a "good guide", the reason it's a guide is because FFR wants the builder to own the build, and build it the way they want to verses how FFR tells them too. On Page 6 of the manual It also states that it's "NOT for everyone" and later on notes "As fun as this project is, a person should be candid about their ability turning a wrench. This is not a place for novices."
Page 7 of the manual Dave has a great analogy of comparing a FFR kit car to a child, there will be highs & lows, there will be frustration, there will be rewards and in the end there will be pride with the completed projects however once the car is built like a child being born there will still be work to do. His point, is there is not written guide that will cover the uniqueness of every child and the same is true for FFR kit cars.
Very hard to write a manual for a one-off car. Where FFR mounted the PS Controller and documented it in the manual, doesn't mean it's intended for everyone to do it that way, it's just a suggestion / option.
When I did my build I pretty much only used the manual as a reference, half of the time the manual sat on my work bench collecting dust, it was only when I came to a part where I was unsure of the general location of something or the order of assembly of a part that I went back to the manual.
Enjoy the build, make it your own, that is the true intention of these kit car. When you get stuck, relay on networking (the FFR forum, FFR tech support, etc), those places are your best manual/guide.
Jim
Post Thanks / Like - 0 Thanks, 5 Likes
Mastertech5
Potential problem with this location??? I too mounted the PS controller behind the dash, fastened to the firewall tube framing. And yes, I did have to extend a wire or two to reach the PS motor. Now, when I drive the car, the power steering fails a few miles into the drive. I'm assuming it's a temperature issue caused by engine heat. Is the motor getting too warm? or, the controller getting too warm? The firewall is insulated. Does anyone have thoughts or experience with this problem?
Not easy, but I would start by checking all your wiring connections and splices. Sometimes the vibration from driving will make a poor connection show up. It won't be able to carry enough current through it. I'm not far enough along to drive mine but I did test it.
Plimpton, which controller do you have? The one that came with my car will give error codes.
With the controller inside the car it shouldn’t be overheating.
How close it the PS motor to the exhaust manifold/pipe?
A little more info: I built my hot rod as an open cockpit car - so no air conditioning. I only drive the car 2-4 times a month and the issue does not occur every time. So, I'll need to make a dedicated effort to drive it enough to try and nail down the conditions under which the failure is occurring. I am in Alabama so, we have our share of hot weather but the last time I had the problem it was an 80 degree day.
The PS motor is probably not close enough to engine exhaust to cause a problem. I guess wiring or connectors is always a possibility - I'll check the ones I can get to easily. There are a couple of connectors within inches of the engine exhaust. Can they get too warm to fail, until they cool back down, and then work again?
Jim, I do have the unit furnished with the car. Thanks for reminding me about the error light. I'll check it next time I experience the problem.
i put mine on the inside of the firewall on drivers side behind the brake master cylinders mounted to firewall. accessible from the access panel in the engine compartment.
