Results 1 to 5 of 5
Thread: trans tunnel size question
    May 2013
    OH,KY,WV tri-state area
    I'm looking at driveshaft safty loops.
    Think this one will fit up in a roadster trans tunnel?? $27.98
    https://www.ebay.com/itm/29488468812...Bk9SR8L84q62YQ
    Raleigh NC, OIB NC
    The Metco piece is not a universal. It was designed for the FFR, is made of heavier steel & is a straight bolt-in. No cutting or fitting will install in less that 20 minutes.
    Pic was taken during install. Long studs were place holders & replaced with the bolts from the package
    Kevin
    MKIV #8234
    On a roll Al_C's Avatar
    Wheaton, IL
    Agree with Bear-AvHistory: I like the Metco piece as well.
    May 2013
    THanks, I didn't know there was one speficly for a FFR. ill get one of those.
    Nov 2018
    Centennial, CO
    Quote Originally Posted by Ford & Jeep Fan View Post
    It does:
    It is a lot of labor, though.
    Bradley
