I started with a frame dolly and jack stands. Once the engine went in the car, I was going up and down so much with the car that I decided to splurge on a quickjack 5000. By no means necessary but does make your life easier. Was much cheaper than other lift options and easy for low ceilings. The plus was it was portable so a lot of the time I would move them in the driveway for my other vehicles without having to move my build. as stated not necessary but a nice to have. Below is pic of the car during the build on the quickjacks to give you an idea of height and accessibility.
However I still used jack stands at times if I needed to access the transmission area. But using the quickjacks to set the car on them was much faster then jacking each corner.
