As usual Kleiner the Grand Poobah of Roadsters is correct.
With a minimum of cussing and fussing I was able to read the rear 1 2010and both were the same. I had to get busy with the right front to get the sleeve down to find 28 2009. The left front has the decal lower than the right and so far I can't read it. Since the decal is in a different position I don't expect it to be of the same lot. I took several pictures and I'll try to pick up a clue there. I guess what had me spun up was having to roll around in a cold garage right before Xmas when that was about the last thing I need to spend time on right now. If the date code was "very easy" to find as referenced in the recall it could have been a 10 minute job. Perhaps they can reposition the decal on future products.
