Thread: Fitment issues with BBK 15150 Shorty Headers
    Kingsland, TX
    Getting the engine together for mock-up -- looking pretty good to me!
    Attachment 183979 Attachment 183980
    Then I spotted this:
    Attachment 183981
    The header flange is hitting the block where the bellhousing bolts!
    I seem to remember other builders having this issue and wonder if it's a quality control issue at BBK. I sent a email to Summit and to BBK. I'll see ho answers first and how to take are of this...
    Dublin, OH
    Can you just clearance that flange a bit? I built a roadster which requires you swap the headers side to side and I had to clearance one of the flanges to get a socket on the spark plug.
    Nov 2015
    Elverta, CA
    i'd pull that header and clearance the block rather than the header. These's a lot of meat on that casting and soft iron is a lot easier to cut thatn the flangs afer it's been heated from welding. Also, you open yourself up to rust on those nice coated headers if you grind away at them.
    Kingsland, TX
    I don't think grinding either would work. It looks as though the ear with the bellhousing bolt would have to be completely cut off to clear the exhaust pipe!
