0
Originally Posted by
michael everson
Instead of doing that, pull the barb out and tap the hole to install your water temp sender. Ron Everitt taught me that trick.
Hey Mike... thanks for the suggestion, but, I already have a coolant temp sensor installed in the eng block by the oil inlet and outlet. And, I wouldn't want to drill and tap and run the risk of metal filings getting into the coolant/engine block.
Mark
