Results 1 to 5 of 5
Thread: Fuel gauge running backwards
    Senior Member Chainsaw's Avatar
    May 2020
    St. Johns, FL
    My fuel gauge is going “up” instead of “down” as I burn the gas off. I’ve made no mods to any of that system and used the supplied connectors/plugs. Any recommendations on how to remedy this?
    Jack
    289 Roadster complete kit ordered 8/2/21. Delivered 3/14/2022. Chassis #10306. 17"x9" Halibrands, 3.55 IRS, PS, Wilwood brakes, BPE 306 with EFI and close ratio TKX. First start 7/20/2023. First Movement 9/24/2023. First go-kart 9/25/2023.
    Build thread - https://thefactoryfiveforum.com/show...rida-289-Build
    Calibrate it per the Speedhut instructions. With the complete kit's sender use 7/8 as the preset value while calibrating.
  3. Thanks Chainsaw thanked for this post
    Dublin, OH
    don't look a gift horse in the mouth. you have one of those magic gas tanks that fills itself!!
  5. Likes Chainsaw liked this post
  6. #4
    May 2013
    OH,KY,WV tri-state area
    polarity backwards on signal wires??
  7. #5
    Senior Member Nigel Allen's Avatar
    South Australia
    2 wire Fuel level sender is resistive and not polarity sensitive. Faulty gauge, or most likely not programmed to suit sender. Jeff is on the money.
    Gen1 Coyote / TKO600 / IRS
